Discuss Galv steel to copper in the USA area at PlumbersForums.net
Plumb Tidy
Hi lads any ideas how to join what looks like galv steel to copper. This is the flow pipe to and from the boiler the steel pipe has rubber away on the joist and has corroded.
True weld
compression fittings normally a 3/4 olive
I’m not sure how old it is there was a back boiler in the property that go decommissioned then this got put in. Would a normal 3/4 or 22mm compression joint do it?
yes 22mm with a 3/4 olive
Great cheers Shaun the true weld you spoke of. Do you believe that’s what’s used to solder the two pipes currently. I usually repair car radiators with some silver solder and rods more like brazing can that be done in this case as it’s non potable water? as I have been wondering what they have used to solder up that’s there already. Cheers for your help mukka!
[automerge]1604956932[/automerge]
I will go for the compression fitting with a ptfe chaser just the solder is a bit more of a better finish
that’s the name of the tube
standard leaded solder used
[automerge]1604957031[/automerge]
you can try soldering but sometimes you can have problems getting it to hold / leak free
Sorted with a compression fitting as Shaun suggested it was a little loose but a roll of PTFE later it was sorted, cheers lads!
Did you use a 3/4 olive in the compression fitting ?
Yeah fair enough I did get excited and forgot to pick up the olive I just contacted them to see if all is ok and the first sign of a leak or when I’m in the area I can change it she was happy with that free of charge of course who wouldn’t be happy with that .
Reply to Galv steel to copper in the USA area at PlumbersForums.net
Hi Guys, I am looking to replace radiator as the old threaded valve is shot on this old building but it is attached to what looks like 1 inch...
Hi there I’m 10 weeks pregnant and found out we have some steel galvanised pipes with corrosion which was causing our tap water to run...
I'm wondering if a failed gas line test indicates a gas leak. If so, is it a requirement to upgrade gas supply line from galvanised steel to...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a...
Hi all hope all is well with everyone. Im a plumbing and heating engineer and I have worked only on domestic systems but am currently crossing...
