Discuss Future jobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sanke
Hi all
i need to start organising future / annual work. Just trying to see how guys schedule annual boiler service / gas safety checks etc Do you use a diary ? Filing system ? Or electronically ? Thanks
just a spreadsheet on the laptop, as its easy to update when they cant afford a service this yr, with colours for oil/gas/lpg and serviced and binned this yr. colours allow me to see instantly percentage of oil v gas, an if the oil keeps building Im a happy bunny
Reply to Future jobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, need someone to do my annual gas service and issue me a domestic gas safety certificate. In addition the megaflow cylinder needs checking and anti corrosion electrode replacement (have the part). In addition some of the honeywell motorised valves need replacement.
We have a Daikin Air Source heat pump feeding our hot water and under-floor 8 port manifold heating system. The Daikin has just had its annual service and the engineer commented that the water looked discoloured and that the inhibitor needed replacing?? Is this an easy procedure? I'm pretty...
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a Glow-worm gas boiler working in conjunction with a Boilermate 2000. The central heating pipework is microbore. In view of the age of the boiler and...
Some advice needed please re a 3 year old combi gas boiler. The hot water works but no heating. A gas engineer was already booked to do the annual safety check before the fault developed. He said the boiler is ok with no fault. He said there must be a leak under the floor boards causing hot...
