Discuss Fortic tank is overflowing in the DIY Plumbing Forum area at PlumbersForums.net
Fortic tank is overflowing,plumber replaced ballcock, no change. Came back and says immersion heater thermostat needs replacing? Water appears to be re-entering cold section via pipe from cold tank to hot cylinder, not through vent pipe. Water is warm in cold section. Any advice welcome
Anything changed on the system?
Reply to Fortic tank is overflowing in the DIY Plumbing Forum area at PlumbersForums.net
Hi, I wonder if you could help me. The overflow pipe drips intermittently from the large cold water storage tank in the loft. Not the small F and...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
