Discuss flux brush after soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Chap did not put any solder in the joint though only on the outside.
Thought the technic was.used.to help make sure solder.had.run all the way around?
no as the solder should of already run/ entered the joint
Watched him do it a few times on his jobs and blow me not one leak. Have not tried it myself.
Yes it does hold pressure, wish I had filmed him doing now. Could have gone plumbum viral :stuart:
No,i am a proper plumber i use my fingers,flux the pipe,assemble,solder,wipe with wool or a dry rag,wet rag when cool
Reply to flux brush after soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm putting a new yorkshire fitting on the end of a pipe from which an old fitting has been removed. Do I need to remove all traces of old solder...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
I'm a complete notice and I working on my heatings motorised valves on my S plan system. I was modifying the system to add an arrester. Long story...
I'm currently refurbishing a room. Plumber has been in for first fix to lay new pipework for new radiators. He's laid fresh copper pipe, however...
2K
