Discuss Flues in voids in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thoggy
Hi all
been to a apartment today and the. Boiler is twin flued it goes above the ceiling and under the floorboards of the apartment above about 7 meters to the outside, both flues for the boiler come out about an inch from each other. Obviously you can't get your head up to look at the full flu length so where do the inspection hatches need to go? Is it near every possible joint or at sections to see the whole of the flu? Even if I put the hatches in they will be on the plasterboard ceiling and look stupid but you won't get your head up as the floorboards are there so do you just use a small mirror to check.
I normally work on standard flus so just looking for some advice from you guys that come across this more often.
Cheers Martyn.
TB008 will give you the information you need but basically inspection hatches should be a maximum of 1.5m from any joint or deviation. Gas Safe also have a online learning programe that is good. Just log in using your licence card number and reg number.
just coz it doesnt look pretty isnt an excuse for not putting in an inspection hatch
And it's acceptable to inspect with a mirror as you would never get your head in to see properly.
Ne1lson
TB008 doesn't say a hatch EVERY 1.5m, it says within 1.5m of every joint which isn't the same thing
So what is the maximum full length piece of flu, it is a glowworm xtra fast 96. I don't want to rip the ceiling to bits unnecessarily. Like I said I'm just looking for some advice as I usually just use a standard flu and these are what I come across on a daily basis.
any hatch would need to be fire rated to the same level as the ceiling which could will be atleast 1 hour plus, maybe even need to be upto 4 hour depending on the building construction.
Even if I put the hatches in they will be on the plasterboard ceiling and look stupid...
OK, it might look stupid… On the other hand you’ve got someone's life on the line… I don’t thing you’ve got much choice, Martyn.
I know that it doesn't matter what it looks like, like I said I don't come across these types normally. I am gas safe but I don't pretend to know everything and I care so the minute I leave a property I can sleep at night. I am genuinely just looking for advice.
Reply to Flues in voids in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys and girls. So…. Bought an apartment in a conversion rather than new build. Since buying it I’ve been experiencing headaches, sickness...
2K
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
Hi all, Excuse the length but this seems like a complicated fix. I lived in a 1930s block of flats. Brick building with concrete slab floors...
2K
I've searched this forum but cannot see anyone else reporting a similar problem with the last generation grey Hep2O fittings: they unscrew! Our...
3K
