Discuss Flue problem . How best to get it looked at ? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I’m getting water in my boiler which I think is coming from the flue (pictured). Is it likely that the issue is with the flue itself or the roof junction? I guess if it is the roof then I’m better asking a roofer rather than a heating engineer - right?
I suspect it’s coming through via the flashing eg running down internally on the outside of the flue eg going through the rubber you might be able to get some black jack roofing mastic
For the rubber to metal joint
Reply to Flue problem . How best to get it looked at ? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
