pauls
only place i can put the boiler is in the kitchen, i cant get the flue anymore than about 250mm ish from a window the flue would exit 250mm above window and 200mm from the edge of window
Discuss flue position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
anyone know why theres still a min distance from air inlet to window ?View attachment 490
Hope this works. Its from the Greenstar Jnr i range of combi's from Worcester.
id like to know that one to steve me and my boss were disscussing it today and think these people just make these things up when they like
thats what i thought but when i checked on vailants site there is a minimum of 300 mm above an opening not sure when this came in im sure it wasnt there beforewhere do you see a minimum distance from air intake to opening? if it is a concentric flue then you measure to the flue and ignore the air intake, on the original post, if i read it correctly and the flue exits above the window then there is no problem with the 200mm to the side
Reply to flue position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
