Discuss Flue integrity failed I'd or at risk in the Gas Engineers Forum area at PlumbersForums.net
flue integrity test failed on a room sealed boiler however not effecting combustion and not leaking into room, would it still be I'd or can it be at risk.
Id
Unless it’s right by a road then a re test is required to check it’s nothing to do with the road pollution
I'm self employed so I'd just repair it.
If its failed on O2 on supply air then its usually just a seal (if not atmospheric).
I'd check fall on flue too.
If its minor and I can book it in within a few days then Its not a big deal
Reply to Flue integrity failed I'd or at risk in the Gas Engineers Forum area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
  • Article
