Discuss Flow & Return Feeds into Radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
TBOE _ top bottom oposite end is the most efficinet way of doing it and normally all commercial building use this method. may save you 5-10% but on 7 rads would you notice a difference? Maybe on 100 large commercial rads it would make a big differnce, hence most domestic have BBOE - bottom bottom opposite end.
You can get BBSE - bottom bottom same end, sent me nuts first time i saw it, thought, how can that work???????? then realised its a specific valve that allows it!
Does the flow go to the bottom of the rad or the top as a rule?thanks
Please register and start a new thread. You're sure to recieve pleanty of advice on this..
Reply to Flow & Return Feeds into Radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Sonya K
