Discuss flow regulator valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mark_mc
i was thinking of installing a whole house salamander pump the only thing is that i have to pump the taps and all aswell.
can i fit flow regulator valve on the pipework to the basin hot and cold to regulate the flow to the taps so that the pressure for the pump does not splash everywhere??
or is there any other ideas?
dont see why not, or just dont turn the taps on full, ok for you if your used to it but could catch out any guests and make them look like theyve peed themselves.
Reply to flow regulator valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hello, I’ve been doing my first refurbishment is a two bed flat with a bathroom and ensuite . Learnt a lot and been grateful for input’s...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
