Discuss Flow and return pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Ktm640
Im currently replacing the central heating system in our house and have the following question.
Our house has solid floors downstairs so both the upstairs and downstairs radiators will be supplied from 22mm flow and return pipes routed between the upstairs floorboards and downstairs ceiling.
Can all radiators be fed from one flow and one return or do I need to split into 2 zones?
Thanks in advance.
Steve
Haven't bought them yet so not sure of final sizes but quantity will be 10. Old ones are all sorts, some singles, couple of doubles and various sizes.
Hope this helps
greater than 150m2 floor area and you are supposed to have 2 heating zone on ground and first floor if you comply with building regs
Hey Steve
Yes you need to have two flow and return 22mm primary feeds to and from boiler, you can then take feed of primary pipes to radiators
If you are taking the feeds from the second floor down to rads below then just remember to install draincocks on every drop you take down so as you can drain that leg in future, this is generally known as a drop system and is mostly used on sealed systems
I'm going to use hep2o after the first 1m off the boiler for the flow and return. Would you suggest always connecting to the rads with copper? I've read that you can connect hep2o straight to the valves but I'm more concerned about the sagging of plastic pipe compared to the rigid straightness of copper.
I would do 2-3m if you could before you change to hep and yes copper to rads
Great stuff, many thanks for reply.
I will be using copper to connect all the rads and where I have solid floors, I will drop down the walls in copper.
I want to use hep in the void between the upstairs floorboards and downstairs ceilings to avoid cut outs in the joists.
Is this advisable?
Seems to be a lot of mixed feelings and opinions when comparing hep to copper!
Many thanks.
Is this advisable?
Many thanks.
Will be fine aslong as installed to manufacture instructions
Got our plumber fitting the boiler, flue, doing the gas supply and commissioning the boiler. I'm just installing the pipes and rads.
make sure hes gas safe, if you dont have his gas reg no ask for it
Thanks for the advice, he's all legit. Gas safe, Worcester installer etc. I'd get a pro to do that part of the job even if it wasn't law. Anyone having a go at the gas etc themselves is plain stupid.
good and good for doing the checks most dont
Reply to Flow and return pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello folks I've moved into a property last month and started to note things that may need looking at. Some of the radiators on the ground floor...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
Hi new to the forum here and after some advise please. I have done a garage extension and need heating in the room. I am in a town house with no...
3K
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
