Discuss Flex hoses for mixer tap - which one is for hot water, which one is for cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
miketimperley
I have just bought a pair of flex hoses for my kitchen mixer tap. I have noticed that the joint ends to the tap are different, one with a long tube shape and the other short. Which one is for hot water and which one is for cold water? why are they made different?
thanks
mike
Hi there
The flexis you mention are standard. The end that is long and thin fits to the tap body. You dont need to put a pair of grips to this. Maybe a little tweak is all that is needed.
Some come with colour code tape i.e. red hot, blue cold. Cold is on the right, from below its on the left, got the idea? If no tape, no prob.
The reason for one being longer than the other is so you can tweak. if they were the same lenght, you couldnt put a spanner on to tweak.
Hope this helps.
Word of the day is TWEAK!!
As tipintim says, it doesn't matter. The different lengths just make it easier to access with a spanner.
put them on either way round, unless labelled otherwise as already stated by tipintim
If you ever have to replace them, be aware that there's more than one type; some have mm smaller diameter threads.
Guess how many trips I made to the merchant to find that one out?
Reply to Flex hoses for mixer tap - which one is for hot water, which one is for cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Got intermittent hot water coming the from a combi boiler to kitchen mixer tap when it hits the T junction for the upstairs bath it's hot, but on...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi all Hope you can help We have a Gloworm Ultracom 38CXI combi boiler. During the Summer the taps and mixer shower run hot water consistently...
