Discuss Fitting of a Unvented Direct Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nkhan
I am looking for someone to fit a 80l unvented direct cylinder in the Luton area
This cylinder will serve one bathroom by itself and will not need connecting to an existing boiler
Thank you
Pls explain to OP how is UHWC will feed 6 jet power shower when there is 2bar pressure and 15L per min
also there is a combi boiler in the loft that is to do the other bathroom and ch
cold feed mains is 15mm to new cylinder position
That ain't going to help ! Strange thing is no one else mention this to customer ......
Unless Magic is a name for a company that build accumulators
The text below i took from fabdec website
BBA approved, the EXCELSIOR water heaters do not require a header tank so can be sited
anywhere on the property, subject to suitable plumbing and water pressure. A minimum
requirement of 1.5 bar pressure and 15 litres per minute flow is suggested for satisfactory
operation – although most homes in the UK now have pressure of more than 2 bar.
Going by this i would assume i am ok as a consumer buying this product not saying you are wrong as a installer
i think you need to do your sums on the water usage.
Likely the power shower is unsuitable and in the event it is suitble for mains pressure (doubt it will be)
at 80 litres of hot water fort hat type of shower you wont be in there very long!
OP you need a accumulator to make it work as you have only 15L per
minute to the house !!!
Many thanks for the post, this is more complicated that I anticipated
How long do you reckon 80l will last, I was going for a bigger one but was advised I wouldn't need a bigger one to serve 1 bathroom
15l/m at 1.5 bar is pathetic.
The water will be dribbling out of your shower heads.
Yep Killy is right. Cheapest and easiest option. Set up a nice big open vented cylinder on a s plan on combi with a. Turner pump. U will need two coffins for water storage so u will probs have nearly 600l of water in your loft. Very heavy.
Killy Bing, interesting post
I have my old water tank still in the loft
Is this doable with a combi as my combi is being installed next week
Somehow managed to delete my post..
i suggested vented cylinder, coffin tanks and shower pump.
is stan installing the combi?
I would suggest an indirect vented cylinder, having a coil to heat it as well as an immersion.
you would need to have the combi boiler "zoned" to give control of the central heating and also the coil on the cylinder.
To give you the needed pressure you would need a twin impeller shower pump.
I'm sure stan can advise you on what you would need.
I'm not sure he was that interested in stans advice bill.
OP. Listen to Stan, he knows what he's talking about. Even if it's not what you want to hear.
A lot of dodgy guys out there will fill up and forget you exist with a sub standard system that won't suit your requirements.
British Gas are installing the combi, was thinking of installing a system boiler but was advised to keep the new bathroom separate from the rest of the house
Was under the impression it would be easier this way
Im sure he's now got his second, third and fourth opinion now.
back to the op, thinking about it, you would be worse off with an 80ltr unvented cylinder than with the combi feeding the shower.
your combi can supply an "unlimited" supply of hot water but with commonly a reduced performance over an unvented cylinder.
in your case performance would only be a marginal improvement but with a limited supply of hot water.
Not a case of not being interested, Stan was the only person advising this way until now
i understand there is a lot dodgy guys out there, that's is why I'm here asking for advice as I'm the one who will be parting with my money and I have to be happy as I explained to Stan
Yeah, easier to spec for the salesman in his suit who's probably clueless.
Get a proper outfit in. BG are rip off merchants
Out of curiosity OP, did anyone else actually bother testing your water pressure and flow?
Yes I got Affinity Water to come out and test
I was gutted I got them them to come out after I had tiled my extension floors otherwise I would have got the pipe coming in upgraded
The guy told me I had 2 bar pressure and the water flow is good but gave no figure for the water flow
If it would be make it easier I will get someone in to test this again and give me figures for both
Pavement tells you nothing other than what you have in the street.
Stan has done the tests required to know how best to advise you.
Scrap BG. I'm willing to bet Stan can fit you a full system that will work properly for around the same or only a little more than you're paying BG for a combi. His rates are very fair - less than I would work for to be honest.
Also you won't have to pay ÂŁ200 a year for a warranty.
Thanks for the input
Now I have more than just a second opinion I can think about how I want to proceed with this
i just want the job so that I'm happy at the end and it looks like there is no point in me installing an unvented xulinder
thanks to everyone who has made a comment, you have all been very helpful
Reply to Fitting of a Unvented Direct Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
