Discuss Fitting back to wall toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andyfto
I am having trouble figuring something out, I need to cut a piece out in the panel that pops on and off to allow for the flush and waste pipes (panel is the full height of the unit, not a 2 piece one) but when the panel is fitted and toilet positioned i cannot see how i would reach down to connect the waste and flush pipes.
If i try to connect the waste and flush pipe when the panel is fitted and toilet is away from the panel so i can reach behind to connect the pipe then the flush pipe wont reach.
If i fit the toilet and connect the pipes without the panel fitted then the panel wont fit on afterwards.
Please help!
Thankyou
Andy
you either set it all up rigid and slide the pan back onto it or you use flexi pan con and flush pipe
Reply to Fitting back to wall toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
