Discuss First post and seeking a plumber who is experienced fitting gasification boiler etc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tlaw259
First post and am hoping this forum will result in our finding the right person.
Seeking an experienced plumber to fit:
  • Orligno 25kW Wood Gasification boiler
  • 1000 litre buffer
  • 100-litre expansion
Effectively all the pipework between boiler / buffer and expansion tank.
Also need feed pipes between buffer in/out and zone valves.
If this leads to certification for RHI, great, if not.....ah well!
Boiler / tanks on a base ready to be positioned.
Immediate engagement for experienced plumber.
No rush, will wait for right person.
Will respond asap to feedback.
Re: First post and seeking a plumber who is experienced fitting gasification boiler e
Location might be handy
Doh!
GU33 postcode.....not far from Liss Hampshire.
Thanks.
We could do it :)
I think, Nostrum could as well, though ot may be a bit cross-country for him.
p.s. if you had bought it through us it would have been 5% VAT on the lot not 20% :)
Are the units new or second hand? if s/h then not eligible for RHI.
You'll need a thermostatic mixing valve on the buffer outlet - ideally weather compensated so that you don't burn yourself on the rads. (And a few other controls :) )
My contact details in signature (click on the links)
If we did it we'd stay in a local b&b until finished.
One we did earlier :)
Orligno 40kW, 2000 litre buffer 2 x 100 litre expansion vessels (give redundancy)
Like the enthusiasm, thank you for responding, appreciated.
I'll PM you with more info (Including answers to questions you already asked (Above)).
Thanks.
Reply to First post and seeking a plumber who is experienced fitting gasification boiler etc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, from South Devon. Firstly - I'm not a Gas Safe RGI. I'm considering my options to replace a 23 year old |Ideal Classic FanFare 50,000 kw...
3K
  • Locked
First time posting on here and I am after some help and advice on a project I have ongoing at home - a bit cheeky I know but as they say around...
2K
  • Locked
Hi and thanks in advance for any advice It’s a little long as quite simply I need to be sure whether I can get a free repair as it’ll be after...
6K
L
  • Locked
Hi Please could I get some advice from all of you who will no doubt be much more experienced than I am. My situation is as follows: I currently...
2K
N
  • Locked
I really hope I explain thos clearly..... I need to change the heating system in my house as we are totally dependent on oil at the moment, I...
18K
Blackcatgas
B
