Discuss First fix pipework testing. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
How do you guys who do site work accurately test first fix pipework etc before the gas meters are installed? I have got a few external gas runs that I have done, awaiting 8 meters to be fitted. The builder wants to paint all the pipes and take the scaffold down but the meters aren't due to be fitted for another 3 weeks or so. Is there an accurate way of testing so I can test what is in before the meters are fitted?
blank any open ends and make a fitting from meter to gas test nipple and use one of these
Gas Pressure Test Tee | 3 Way Test Tee | Gas Pressure Testing Equipment
with either a u gauge or your kane or other etc
Reply to First fix pipework testing. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've air tested pipework for years, typically 4 bar for 30 minutes. I've never had an issue with any pipework that has passed that test, occasionally you get a small leak from the air test typically old cap ends/scratched pipe which shows up easily on the test without having to inspect anything...
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our property, and the property itself. The water company fitted a new (smart) meter about 4 weeks ago. Now they have contacted us saying we have a leak...
1K
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the working gas pressure on the gas valve test nipple. This fell to 8mbar on maximum and 17mbar on high setting. They then removed the isolation valve under...
Hi, moved into a home a year ago with what is probably an old heating system. There is a gas boiler linking to radiator central heating, and a water tank. Energy company charged an enormous amount for gas last winter (admittedly I hadn't taken regular meter readings so was unaware until a huge...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
