Discuss First fix pipe work testing in the USA area at PlumbersForums.net
Hi
Just using a rothenberger RP50 to test first fix radiator pipework.
part HEP and part copper.
what is the correct procedure?
Struggle to pump it up to 4.5bar!
Used pump to put water in the system then vented the air and then pumped up but became very hard to pump.
Long time since I did this at college
Cheers
Phil
Check the manufacturers instruction
It’s something like 5 bar for 10 mins
10 bar for 5 mins
get a better pump if you are struggling as it should be pretty easy unless it’s a huge system.
you can fill by mains first then pump the rest
You can get by with a drill pump to fill the system then use the rp to pressure test
Reply to First fix pipe work testing in the USA area at PlumbersForums.net
Hello all I have had an extension built which will have 3 radiators to the big main room, a utility sink and a shower room (ground works, waste...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
hi all i got myself in a muddle. a friend of a friend came around at xmas to help me line up two copper pipes for shower bar install. the pipes...
2K
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
A
So house 4 years old. In that time had 7 pipes burst. Builder fixed first one, blaming cylinder not being serviced. Over the 3 years another 2...
