Discuss Fire valve external oil boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
Bit of help on the regulations please?
An external oil boiler (metal case) sited outside the house but contained in a slightly larger wooden enclosure (foot bigger in all directions, ie not a shed).
Would it be acceptable to place the fire valve inside the wooden enclosure?
I've looked through my books, although not up to date but most is still the same it states the fire valve should be installed outside of appliance casing with the sensor above the burner. Regulations used to state a minimum of 2m i believe but I think some manufacturers are now fine with it closer.
I take appliance casing to mean the original metal case not the new box surrounding it...
However what threw me are the oftec rules stating
Fire valves are also required for external boilers, with the cut off point located at least 1m away from the appliance
[automerge]1604008772[/automerge]
straight out through the casing, then out the wooden box
Yes, appliance casing being the boiler casing.
My books are not the recent ones as I said as I am not currently OFTEC, I'm off work due to health problems actually. It used to be a minimum distance but as I understand some manufacturers will warrant the installation if closer.
If you got any doubts just phone OFTEC in the morning and ask them directly.
We normally install external boilers with a 3mt fire valve fixed as far away as is practical possible.
Out of interest what clearance has the flue from the timber surround?
Reply to Fire valve external oil boiler in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hello. I'm hoping to get some advice. I moved into a new build house a few years ago. A Firebird Silverpac external oil boiler (kabin pak type)...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
Been in property about 10 years and the valve on the (round/bunded) Balmoral tank has always been in pretty rusty state. Tank is 5,000 litres but...
Hi, Looking to see if anyone can give some advice please. My Baxi boiler has been losing pressure and I am having to top it up approx. every 4...
