Discuss Fibreglass 5 gallon tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Evening all,
Where would one source one of these, are they available?
Lol.... I knew somebody would have to ask. About to start the plant room of a large new build in the basement, my plan is to put both the pressure relief’s from the unvented and boiler into it, have a 1” overflow from it into a sanicom 2.
And yes the sanicom can take very hot water for short periods, but me and the customer are thinking of ways to activate an audible alarm to detect if the unvented blows off the temperature relief valve into it. Maybe a heat sensor on the lid of the tank or a float sensor to start the alarm
Dunno, just trying to cover all bases
Sani con not rated for boiler or unvented or condy That's what I was told from sani
Have a look at pump house
@rpm
I’ve never known of a temperature relief valve go off, not saying they don’t .... but the high limit would kick in and close the zone valve and within 10 minutes cold water would’ve emptied the hot water, that’s why I’m asking about the fibreglass tank with copper overflow.
Have you lot thought of the 1000’s of f&e plastic tanks on solid fuel systems, that hold near boiling water
I’ve never known of a temperature relief valve go off, not saying they don’t .. but the high limit would kick in and close the zone valve and within 10 minutes cold water would’ve emptied the hot water, that’s why I’m asking about the fibreglass tank with copper overflow.
What happens if port valve fails have to design system to cope when they fail
Also solid fuel are specd at copper or steel also copper floats
If the valve fails, the limit is the boiler output temp....which will be about 70 degrees.
That's if the stat is new it's one of those things it could might never do but it could
Bloody hope so, it’s a brand new Worcester Bosch.
You worry to much lol.
I’m not in the habit of doing things unsafe. I’m trying to cover all bases, hence the sensor business. I’ll put up some piccies shortly of the progress
I would wait on installing the sani tho
Reply to Fibreglass 5 gallon tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
