Sharp Point
Evening all,
Where would one source one of these, are they available?
Discuss Fibreglass 5 gallon tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We had the saniflo rep out on site in the boiler room , who specc’d the sanicom2Sani con not rated for boiler or unvented or condy That's what I was told from sani
Have a look at pump house
@rpm
It says 90 degrees intermittently Shaun
So no then not acceptable for an unvented
It was specc’d by the sales rep Shaun
I’ve never known of a temperature relief valve go off, not saying they don’t .. but the high limit would kick in and close the zone valve and within 10 minutes cold water would’ve emptied the hot water, that’s why I’m asking about the fibreglass tank with copper overflow.
Have you lot thought of the 1000’s of f&e plastic tanks on solid fuel systems, that hold near boiling water
What happens if port valve fails have to design system to cope when they fail
Also solid fuel are specd at copper or steel also copper floats
Yes I know, but I bet 90% are in flimsy plastic tanks.
If the valve fails, the limit is the boiler output temp....which will be about 70 degrees.
That's if the stat is new it's one of those things it could might never do but it could
Reply to Fibreglass 5 gallon tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
