Discuss Ferroli optimax he plus 31c expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Myquantum
hi everyone, I have just joined, so apologies if this has been asked before.
pressure keeps dropping to zero. When at zero there is no pressure on the expansion vessel,which should be at 1 bar, it looks like the only way to replace this is to remove the boiler completely.
can I just tee into ch return and add an external vessel ? I presume that I will to blank off the existing vessel. (Boiler is about 4 years old).
thanks in advance for any advise. Dave
Are you gas safe registered? If so you'll need to raise your post count to 10 and send a photo of you GSR ID to gasman or Redsaw and you'll be given access to the gsr forum.
If you're not then it's forum policy not to give out information pertaining to gas appliances in public.
Reply to Ferroli optimax he plus 31c expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
