Discuss Female thread on shower wall outlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need a new attachment to screw onto the wall outlet as the old one has broken. The problem is that it is a female thread on it and I can't get an attachment to fit it. It's a tivoli shower which was made by Bristan but they don't make attachments to fit any more. Help?!
Maybe shower z connectors will fit
Is the silver bit that's broken?
So that's the part what's broken?
I see it's the outlet connection
Any chance of a pic of which end is broken?
It's the end which attaches to the pipe coming out the wall but the whole thing is actually only plastic even though it looks like chrome
If it's plastic sorry to say best thing to do is replace the shower outlet
It should unscrew from the connector in the wall (should be a 1/2 backplate connection)
I've got the same problem - shower hose is bust (we moved in 8 years ago - no idea how old it is). I've got a 1/2 inch union coming but it's longer that the existing male connection and I fear the hex nut will catch on the body of the mixer.
Update: The 1/2 inch union worked a treat. Stuck an o-ring and PTFE tape on both threads, and a regular shower hose, and it's working fine.
Part was listed on Amazon as "1/2" INCH THREAD PIPE CONNECTION MALE x MALE SCREWED NIPPLE". There are cheaper brass ones, but i needed it sent with Prime!
Reply to Female thread on shower wall outlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
