Discuss External condensate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If having to have the condensate discharge externally, Is 32mm 1.25inc or 1.5 inch 40mm waste pipe best? The instruction say a minimum of 32mm.
bigger always best but depending on length of run i wouldn't want to go really over 3m unless frost protection is present
Just extra hassle and a bit overkill IMO, expensive as well!
what armaflex just a tad more than normal (thick) round here about £10 + the dreaded for a 3m length
Seen one in 15mm speedfit yesterday :( I normally use 32mm with black lagging.
location also to be taken in to consideration 3m on a flank wall 10m up will be more likley to freeze than a metre in the corner next to the kitchen door
Reply to External condensate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
Hi, Boiler is losing pressure, from 1.5 bar to 0 bar in about 4 hours. Have checked all rads and seem to be fine, no water out external prv...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was...
