Discuss Existing Flange for shower pump ok? in the USA area at PlumbersForums.net
Im im fitting an ST 3 bar shower pump in place of an aqualisa that was previously fitted
Just wanted to check if the existing flange is positioned in an acceptable position?
The instructions recommend side entry and this sems a bit high (not sure what is considered side entry). Didn't have any issues with the previous pump but wanted to double check before final fitting
Yep aslong as it’s got a dip tube
Yes but be warned you don’t want to disturb the flange
chances are there’s no dip tube but it’s been working fine with the old pump so upto you
Reply to Existing Flange for shower pump ok? in the USA area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
I need to install a pumped shower, connected to a gravity system. Hot water is in an direct cylinder on the first floor, and CWST is on the...
ive been to a badly installed salamander shower pump.No independent cold supply and hot teed off 15mm to whb.If you lower the shower head 12...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
