Discuss Elson coral e leaking brown water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Heather Clarke
Hi my boyfriend has a Elson coral e, he noticed yesterday it is leaking brown water from.the bottom and it is not working at all.
Any suggestions as to what the problem maybe?
Thanks in advance x
There's so much scope to go with here for a daft answer Heather.
Safest to say you need someone in, it could be anything from the immersion failed to a knackered sacrificial anode to a split seam.
Heather,I look after a place with 56 of these, so I have plenty experience with them, is the water around the base of the cylinder towards the bottom right hand side, if it is , it's is time for a new one, if it's leaking around the two immersion heaters it's fixable could you post a pic ?
Reply to Elson coral e leaking brown water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
