Discuss Electric Water Heater Advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
Sorry if this is the wrong category for my question.
Looking for a little advice on an electric water heating system. I have a small cleaning area that has 2 sinks and a spray gun, this is used to clean out refurbished White Goods, so things like Fridge shelves and baskets go in the sinks and fridge cavities get sprayed, ect.
At the moment the hot water is supplied via a Galaxy Aqua Premier Water Heater 9.5Kw - 45793266
However this barely gives us any running hot water, so I am looking to get a replacement for this unit.
Space is limited and I only have a cold feed supply to the cleaning area.
Can anyone recommend any units I can upgrade to?
Cheers
DJ
Hi
I did think about a shower unit at first but the shower would be on almost 8 hours, whereas if you fill the sink and just top up the hot water every now and again would be better water wise as you can steep things in the hot water.
DJ
A 30l unvented water heater may suit your needs if you have space for it. They go from 5l up but obviously get bigger and more expensive the more stored water you require.
Whoever fits it would need a current G3 and you need to see proof of it before you let them fit it, just like you'd want to see the gas safe card of somebody working on a gas appliance.
Agree that would work, just make sure its at least 3kw for the best recovery time, but personally I'd stick in a small proper direct unvented cylinder and then put a proper tap in with a spray, Running costs will be lower as better insulated and cheaper life costing as elements designed to last longer and easier to change.
Reply to Electric Water Heater Advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
