Discuss Electric Showers Performance in Winter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Y
Yous
Hi folks,
I am doing a study for one of my graduate classes. The study is pertaining to electric showers in the UK. I would greatly appreciate all of your feedback.
Mainly, I came across a dilemma - the effect of seasonal changes on electric showers in the UK. Just how much does the performance of electric showers suffer in winter? As I understand, when the mains supply is colder, water needs to be heated for longer and thus passes over the heating element in the shower much slower and the net result is a dribble!
  1. Just how true is my understanding, or how common is this problem?
  2. Does this issue impact all electric showers or just lower kW electric showers?
  3. Roughly, what is the percentage of high kW electric showers sold in the UK market?
Many thanks in advance :coolgleamA:
Yous
1/ Yes - the dial on a shower doesn't control the voltage, it controls the flow of water. The slower the flow, the more time it gets in the shower, the hotter it will be at the business end.
2/ It impacts all electric showers, and combination boilers too. The water comes from the mains, has to pass through a heat exchanger and come out hot at a tap. It will achieve a set temp' rise at a given flow rate. So if you start with a lower temp, you will end with a lower temp' if that makes sense. The more powerful your appliance (in this case a shower) the less obvious the results of a cooler starting point in the winter.
3/ I have no idea. Does any jobbing plumber know the answer to that question!!?
3/ Contact Mira or one of the larger plumbers merchants, they may give you the data.
1) yes
2) yes
3) Don't know the percentage but would suggest showers of 10kw and above would possibly be in the single percentage because of the wiring issues that these present.
i would think as many high kw showers are returned back to the shop than get fitted. Once they get a quote to upgrade the cable size and protection device.
The temperature of water supply from the mains doesn't vary much in reality. It's your impression of it due to the surrounding ambient temp that makes you think it does.
Reply to Electric Showers Performance in Winter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'd love some advice on my system, I've had a couple of plumbers come in that seemed to specialise in gas systems and seemed perplexed by my all-electric systems and the issues I'm having. My system is all electric heating and hot water system, in a flat on the 4th floor. The mains...
Our master bath shower had two shower heads. One was leaking/dripping so our plumber changed both cartridges since he was already there. That fixed the leak, but ever since one side gets too hot and the other side only stays hot for 5 minutes before slowly getting colder and colder. Our plumber...
DianaCali
Current setup: Cold water tank, and header tank in loft. Hot water tank in airing cupboard at top of stairs. Power shower (mira event xs) in main bathroom, and same in en-suite. 20 year old Baxi boiler, still going strong. Background: Need to free up as much space in loft for conversion. Enough...
2K
Hi guys, I want to replace the electric shower in my flat and I'm not sure which is the best option for me.. I want something powerful, but also looks good.. my bathroom fitter recommended Mira showers, and in particular the Mira Sport Max with Airboost.. he didn't know anything about the...
2K
I had a new electrical water heater (Rheem) installed in our apartment - before it was inside the closet, but now we installed in the basement of the building. Due to the new layout, the main hot line is connected to a different point, near the laundry shut off. The old heater tank connection is...
