Discuss Electric Shower choice advice in the USA area at PlumbersForums.net
Hi all, I am about to replace my ancient 8.5Kw Mira Elite shower which has finally died.
The Mira is a tank fed pumped model with the water connection at the very top left hand side and the electrical connections towards the bottom left.
I am planning replace it with a mains fed shower as there is a convenient feed in the loft above with what I think is decent enough pressure.
What would be the best model of new shower to choose with ease of fitting being the main priority? Would anyone go with another gravity fed pumped shower?
Many thanks for any help.
Triton T,80 profit would be my choice , but just fitted a bristan pumped shower for my nephew as a replacement for a newteam one and was a straight swap . Kop
You are guaranteed a constant flow rate with your pumped electric shower, the mains supplied shower is obviously simpler and quieter but require ~ > 1 bar dynamic pressure at the shower to give ~ 8 LPM to ensure constant flow/temperature control with the stabilising valve.
Its your choice but the Mira pumped shower around here has a very poor reputation, a Triton, either pumped or mains would be a good choice IMO, just check that the particular model you choose has the water&electrical connections as the old ones were.
Triton really good value used them myself and installed them for years centralheatking
Reply to Electric Shower choice advice in the USA area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
I currently have an 8.5kw electric shower on a gravity fed system in bathroom which doesn't give great flow when hot turned up but to get a 10mm...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
N
Hi, i'm looking for some advice on improving the performance of my electric shower as it frequently fluctuates in temperature and flow. The 8.5kw...
I need advice on whether I should get a digital or electric shower. The water pressure in my flat is very poor for the shower (gravity fed water...
