Discuss Electric hot water cylinder with mains pressure cold water feeder tank - noise! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DistantHillsBB
Hello
Had a search but cannot find the exact answer.
We have an electric hot water cylinder which has a feeder tank on top.
The feeder tank is filled by the cold main water.
The problem is when the cold tank refills the mains pressure makes quite a loud noise disturbing the bedroom underneath the tank. No parts are vibrating its the sheer water pressure as it hits the existing water in the tank.
Is there a solution or workaround?
New valve?
Pressure reducing valve?
Peter
is there a shut off valve on the mains feed to the tank? if there is you could try throttling back on the flow a bit.
sometimes a service of the float valve will calm down the effects of water hammer.
Thanks for your reply. There is only one valve on the cold mains for the whole house and I don't want to throttle that back due to the demand on water in the property at times. Its a 9 bedroom guesthouse.
Thank you for your reply. Is a service something i can do or do i need a plumber? What is involved?
Do you mean you have a fortic cylinder with an open bit on the top which has a ballcock? If so take off the ballcock and swap it for an equilibrium ballcock
They used to come with quiet ballvalves which had a dip tube on them but ive not seen one for years think they may have been outlawed a new ballvalve may be quieter or insulate the cupboard to stop the noise ? Im amazed that one combination cylinder can keep up with 9 bedroms
Thanks everyone. I will try some of these options.
Steve sorry we actually have two of these cylinders and the showers are electric so there is not a huge demand on the hot water which is just really for the wash hand basins
Sounds like you have a Thermal Store system. Try changing the ballvalve in cold water tank on top. Fit a "quiet type", such as Torbeck.
The system works by the fact that the bulk water is heated DIRECTLY by the boiler. This heats up much faster usually with ONE boiler firing, and then a coil in the cylinder, fed by mains water PICKS UP the heat and directs it to the rads or hot water.
Hope this helps.
Rob Nice.
Forgot to say... Of course it may NOT be a thermal store, which means that you have a simple FORTIC hot water system which has a cold water tank on top of a copper cylinder, with immersion heater/s. Same remedy though. Replace ballvalve. Good luck. A pic will help if I got the wrong end of the stick..
Try changeing valve first ! lots of quiet fill ones on market, pop round local plumbers supply's, ! if no good then you may have to fit a Press red valve on supply to tank,
Reply to Electric hot water cylinder with mains pressure cold water feeder tank - noise! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated house (4 bathrooms is tragic). Current set up is: A hot/cold mixer in the main ensuite which is ok as long as you don't run anything else. One electric...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
