Discuss EcoTec diverter valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
AllyBongo
These easy enough to strip and clean out? Got a cust with a Pro 28 dumping heat down the flow. Dirt inside will prob be my 1st check
Check the spindle and motor other than that your better off replacing
Can the spindles be serviced in any way, heard they are bad for leaking? Exploded views of the boiler don't show the diverter coming apart
You can clean em. Sometimes it works sometimes not. They're not the greatest deaign
Defo not the best design, stripped it down for a look today, the motor was moving fine. The spindle looked a bit bent on the water side of the valve. The spindle was moving through the rubber, at one point the rubber actually came of the spindle. New valve it is!
Two different valves show up on searches, brass one and plastic one. Is it just like for like??? The said boiler has the plastic one? Pro 28 R2 VUW GB 286/3-3. Look like they would both fit?
theres different motors on the newer ones and come with a lead to adapt the wiring i dont think you get the lead with the plastic ones as they are whats fitted to later models
Cheers spoke to Vaillant this morning who confirmed its the older brass one I need. Hopefully there info is right.... Had an issue with their tech helpline last month!
Reply to EcoTec diverter valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd...
J
Morning all, My Vallient Ecotec Plus 831 is stored in the loft and is connected to Hive. It is coming on randomly at various times of the day, but...
J Hughes
J
Vaillant Ecotec Plus 832 boiler is 13 years old, 4 of which since we've been living there, started to play up in last couple of months. An...
