Discuss dripping tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wanttolearn
My mate got a problem with his tap constantly dripping as i got a lot to learn and never worked on one of these before is it just a rubber washer that needs replacing.
If so is it just undo the cap and replace washer from hot and cold or is it the handle that chooses the direction of water to shower head or taps.
Any info would be great thanks
Remove tap heads & shroud... You can then undo the brass nut.... Check washers & replace also shine a torch onto where the washer sits & check there are no pits on the face if so you gotta regrind a new face with a tap reseating tool.
The cold water probably tank fed, so CWS tank needs isolating for both hot & cold.
Reply to dripping tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello folks, I’m trying to fix this slow leaking tap myself and I’m stuck here. How do I dismantle it further to replace whatever needs replacing to fix the drip? (The chrome ring round the top will not unscrew by hand.) Many thanks
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has been intermittently dripping from the hot tap, and the cold tap is squeaking when you turn it. Possibly two different issues, possibly related? The...
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the tap head! i thought the hot/cold circle would pop out but no such luck and don't want to damage. can anyone help? Thanks Martin fix the caple
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
Please can someone advise how to fix this shower that leaks? I guess I need to replace the washers inside the taps. Is it the blue or red one? My local DIY place didn't have the washer last time I attempted this. The cold tap is the culprit, a bit soft to tighten and leaks unless really tight...
