Discuss drilling porcelain tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
roguetrader
hi
anyone know the best make of drill bits for drilling porcelain tiles the size i need are 5. 7. and 10mm the tiles are 10mm thick
thanks
Totally agree, 365 drills are the best. Buy one of their kits, the bathroom kit is good value and cheaper than buying them individually.
I use a masonry bit on tiles make a small whole at slow speed then increase the speed that the jobs a good one. I haven't cracked a tile yet.
As above, mark your hole, get a screw and hammer and GENTLY tap the point on your mark to give you a starting point and stop the drill bit circling around everywhere.
Then use a masonary bit start slow and increase speed as you make your way through.
I have broke tiles before but never through drilling them..
Bosch multi construct bits are really good. Burn out pretty quick on porcelain though so have to be new. I usually try them first then if the porcelains really hard and I'm struggling I use a marcrist diamond bit. You don't have to wet these and they last ages, best on the market I've found so fa,r although not cheap.
Reply to drilling porcelain tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
B
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am...
Billy Barnard
B
Hi All, does anyone know why the water only fills 1/3 of the way please?
