Discuss Dodgy Pump symptoms? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Went to this job tonight.
Reports of no hw and no ch.
All turned off on programmer, i switched on hw and it fired up. CH going on and off as it should, on auto and constant.
These scenarios do my head in, turning up to a job and everything is working - how can you fix what isn't broken?
The pump is noisy and doesn't look particularly new. With the noise i think it's on it's way out and is struggling.
Any common faults with these?
intermittent fault PITA, could be anything from programmer to boiler,normally first signs of a pump dying are upstairs rads working ,noisy boiler and downstairs not heating,but not always,pump may have stuck and un seized its self did you put a screwdriver in the center and see if you could stop it?
I had a similar job recently, the pump was at a high point in the airing cupboard making noises... I changed it & it worked fine for a few days then the pump was making funny noises again!! It was a blocked cold feed, system was running dry almost & the pump on the highest point meant it grumbled first!!
If i have to go back i'll change the pump and go from there
Had a job last year where i suspected the pump was on its way out , last couple rads on circuit were only luke warm and i could stop the impeller quite easily with a screwdriver.
Replaced pump and all worked fine.
You need to be careful Ash, let them know the pump is in its say out. But you can't guarantee it'll cure the fault.
Pumps normally aren't the cause of intermittent faults, it's usually an air pressure with or diveterter valve.
Reply to Dodgy Pump symptoms? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
