Discuss Doc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the retainer
a
b
The retainer on type b is bigger?
So, what do you use most?
I used a type a today on a rad drain.
Tbh, I didn't know there were type a & B!!
no b doesnt have a retainer you can unscrew the shaft all the way out
a you have to remove the retainer to remove the shaft
Ah, I see, Thx Shaun
The top part, thx, where the washer is located.
Any pros or cons?
Anyone better to use?
Thx again
Any pros or cons?
Thx again
not a problem and yes a dont leak when fully open
i only fit a
A type drain cocks have a seal on the shaft which stops, in theory, water running past the shaft when you use the drain. As far as I know they are regulation to use on cylinders etc inside homes
I use type A Ive got a hole tilt bin full of them as I always get plenty when doing a boiler swap but only ever end up using one or two half the time
Reply to Doc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
