Discuss discharge pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adrianfs1
hi all, im currently doing some study work to get my unvented cert, got a list of questions from a revision guide, can answer all but one,
Discharge pipework must have a continuous fall of at least:-
1, 1:400
2, 1:300
3, 1:200
4, 1:100
I have gone through all the litriture i have, i have trawled the web but all i find is that the discharge pipework should have continuous fall, and i believe they are referring to the D2 pipework not D1, anyone shed any light.
As quoted in Building regs G3 3.56 the discharge pipe (D2) from the tundish should:
a have a vertical section of at least 300mm long below the tundish before any elbows or bends in the pipework; and
b be installed with a continuous fall of at least 1:200 thereafter
Hope this helps
thanks for that melmos, i could not find that, did you use google to find thaT
No, I recently put an unvented under sink heater in and looked it up in the Building regs
Reply to discharge pipework in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm looking for some advice on how to proceed with my current situation. We bought a new build and after getting my boiler and unvented...
1K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
I live in a shared building with a flat above me. My upstairs neighbour has just fitted an unvented hot water cylinder. The plumber has run the...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
1K
H
HRP123
H
