Discuss Detecting leaking toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
smccran
Hello all,
I have an upstairs toilet that I think is leaking. It is in an en suite room.
The room underneath (on the ground floor) has a small damp patch on the ceiling where I would estimate the toilet is above it.
My issue is that the en suite floor and wall is tiled so I cannot get easy access. The toilet cistern is embedded in the wall and is incredibly small and squeezed in, so its almost impossible to see anything.
Is there any way to detect if the unit is leaking somewhere? Do I have to take the tiles up or is there some way around this?
Shaun
Have you felt round the waste pipe at the back of the toilet so see if there's any wetness there? a picture tells a thousand words ;)
A favorite leak on a toilet is the water connection on to the ball valve, knact fibre washer or not tightened enough. Stop using it, if the wet patch drys up it is probably on the waste or the pan to cistern connection. If the wet patch starts getting worse and you are not using it, its probably the water connection to the valve. Think you get my drift. Probably a job for one of us lads.
sliding your phone in with videorunning can get places you cant see or a cheap usb camera from ebay
Reply to Detecting leaking toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi sorry im a newbie, pls help if u can. I had a new bathroom installed about a yr ago and since then when i flush the toilet the room stinks of sewer gas. Not only does the b/room stink it also smells in the kitchen too, which is directly below the toilet/b-room. It doesnt do it everytime...
There's a leak in the ceiling of my Dad's living room which is on the ground floor and has a bedroom directly above it. There's an in-ceiling speaker where water was dripping from, and there were slower drips coming from a...
Hi, all. Advice required. I want to install an En-suite toilet and wash basin. It's in a guest room and will only see occasional use. There's no room for a shower pan, but I can squeeze in one of those combined basin and toilet units. My question is - can I install a toilet and basin where...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the branch) and plan to place it the opposite end of the room. I was pretty lucky to find a 110mm sewer waste pipe below the old sink which is the new...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
