Discuss Delayed Cistern Refill on RAK CERAMICS dual flush close-coupled unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Glosguy
My 3 year old basic model RAK Ceramics dual-flush close-coupled unit sometimes has a delay before refilling. The pause before refilling (short and long flush) can last up to 10 seconds before the water inflow starts the refill.
Has anyone any idea how to remedy this re-filling delay?
This is a photo of the inside of the unit: rakceramics cistern.jpg
The flat looks like its jamming on the side of the cistern, that could cause it to fully empty then the float will just drop after a delay, try loosening slightly and clear the side of the cistern
Many thanks for your reply, Stani.
Please excuse my ignorance, but which bit is "the flat"?
Sorry predictive iPad, should say float. It's the bit that looks like its touching the side of the cistern
try turning the screwed plastic rod on the float valve, it will adjust the internal cup float height setting.
pop in a new wirquin float diaphragm aswell.
al
Reply to Delayed Cistern Refill on RAK CERAMICS dual flush close-coupled unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
  • Locked
I know this topic has been thrashed out quite a few times however every situation is different and unique, so here is my story, its a little long...
1K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
F
  • Locked
Hi, I am a newbie here so please bear with me. I have a close coupled cistern that needed to be removed due to a faulty flush valve. My problem is...
1K
ant78
A
  • Locked
Our toilet cistern has a two year old Armitage Shanks 8.5 “ bottom entry fill valve which will not shut off the water when refilling after a...
5K
