Discuss Deaerator or not anyone? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anyone ever fitted one of these or had experience with one.
thanks.Recently had powerflush of severely sludged system and trying to minimise repeat performance.
thanks
If the system has been properly powerflushed (bare in mind this is not a two hour job) and the rest of system is sound then air ingress shouldn’t be a problem once system is filled and bled. Sludge or black iron oxide is caused as you know by air getting into the system over time, my guess is your system boiler was originally an open vented and not properly powerflushed when updated, which should be done before a new boiler and again after completion. Installing a filter on the system should be considered as well, this magnet attracts the sludge as it’s circulating and is easily cleaned during a routine service of system.
Reply to Deaerator or not anyone? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
