R
Rslee
Hi there
Can you please help - our builder seems to have little knowledge of buildings regulations so we are struggling with our extension/conversion.
We are converting part of an internal garage plus existing room into a new kitchen. Problem is there are 2 different floor heights for the new kitchen namely:
1. Most of the floor is block and beam - depth of 120mm below finished floor level
2. A small section of floor is the old internal garage floor so has a concrete slab on top of the block and beam - the top of the concrete slab has a depth of 50mm below finished floor level.
I need to lay damp proof membrane on top of the two different floor constructions. Do I lay membrane across the two different floor heights?
Also in the hallway there is a small part of the floor near the stairs where there is old screed which has been left in place because the stairs are resting on the screed. Below the screed there is some polystyrene foam insulation. How would Dpm cover this area? The hallway area around the small screed area is block and beam with depth of 120mm as in 1. above.
We we are planning on using wet underfloor heating (pipes in screed) then tiles where we have the 120mm floor depth.
Many thanks for for your help!
