Discuss Coventry - groundwork pipe work needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I will need:
install new 100mm pvc pipe work, 90-degree bend for new W/C
install new 100mm pvc pipe work, 90-degree bend with new gully pot at rear of new extension for sink waste
clean water pipe carry out 2 x Lead connections with a new T section
No excavation needed, all is digged out.
Reply to Coventry - groundwork pipe work needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
