Discuss correct dosing of chemicals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
my system comprises of:
FE tank in loft.
ideal classic rs250 about 10m run of 28mm to HW tank CH pump circuit.
3 double panel rads.
9 single panel rads.
unvented HW tank.
do you think I need to use 2ltres of stuff like inhibitor? as it says on the container upto 10 rads.
I would personally put 3 tubs in for good measure I only use merchants own brand so its only a fiver a tub
bum.
maybe that's why I haven't exactely noticed an improvement. ill chuck another ÂŁ17 in then.
p.s. its x400 im playing with.
As AW says along as it has the Buildcert mark on you'll be good. I usually do 1 bottle per 10 rads.
Reply to correct dosing of chemicals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
