Discuss Copper cylinder 1'' blanking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I have a gledhill copper cylinder to fit. It is a direct cylinder containing standard 1'' feed and distribution connections but has the 2 x 1'' connections on the side but no coil in the middle. Can I use blanking plates for these as not required?
thanks
It’d be difficult to tape up with ptfe. I’d be inclined to use a 1” tapered cylinder union and then put a 22mm cap on the stub of pipe.
I like that idea but the Loctite thread sealing string will do a good job on a 1" thread as well. Either one is a good solution.
How many litres as never seen one with 1” connections unless it’s gravity or above 400l ?
You sure it’s not 22mm compression as that measures round about an inch dia
Loctite 55 or 755 would do
Reply to Copper cylinder 1'' blanking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
