Discuss Connection to Boss Pipe Leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, hoping you can help me.
I have a leak where the bath waste pipe connects to the boss pipe. Not sure if its a push fit or pipe weld type. In the pic, it's the lower of the 2 pipes coming from the left. What's the best solution for this please? I'd best tell you that I'm not particularly good at DIY, but am a tryer.
Is there a fitting in there or is it just pushed in ?
You should be able to see if there’s a fitting in there etc
Should be a rubber bung as it’s pushfit pipe you can’t solvent weld but I’m not saying someone just hasn’t siliconed the pipe in there etc
Pipes at wrong angle putting stress on bottom of rubber oring. This has caused it to deteriorate and leak.
You’ll likely be able to pull it all apart.
I’d shorten the closest vertical pipe by around 10mm.
Then replace the oring.
Reply to Connection to Boss Pipe Leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s...
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm...
Hi all, have a leak in landing from upstairs bathroom. This only happens when sink taps are on, not shower or toilet . Think it is a boss...
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
