Discuss Connection to Boss Pipe Leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, hoping you can help me.
I have a leak where the bath waste pipe connects to the boss pipe. Not sure if its a push fit or pipe weld type. In the pic, it's the lower of the 2 pipes coming from the left. What's the best solution for this please? I'd best tell you that I'm not particularly good at DIY, but am a tryer.
Is there a fitting in there or is it just pushed in ?
You should be able to see if there’s a fitting in there etc
Should be a rubber bung as it’s pushfit pipe you can’t solvent weld but I’m not saying someone just hasn’t siliconed the pipe in there etc
Pipes at wrong angle putting stress on bottom of rubber oring. This has caused it to deteriorate and leak.
You’ll likely be able to pull it all apart.
I’d shorten the closest vertical pipe by around 10mm.
Then replace the oring.
Reply to Connection to Boss Pipe Leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Sonya K
