Discuss Connecting toilet to 15mm copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
James100
This is my first piece of plumbing work, so treat me as if I know nothing (which isn't far off!)
I want to connect a toilet to the inlet pipe (15mm copper). I have read that a flexible connector is best, but these all look too long. I have no more than a few inches from the top of the boxing that hides the pipes to the base of the cistern, and I would like an isolation valve in that gap. The toilet didn't come with any nuts to connect the cistern to the inlet pipe, so I was wondering what is best to get a good connection between the base of the cistern (plastic thread) and the copper pipe? Is a normal 15mm compression nut good enough, or would that not give a water tight connection?
Any help/tips much appreciated!
James
Depends on how big the gap is, whether the angle is straight-up or offset.
If you're a novice you might want to look at getting a push-fit connector.
Service Valves
Straight
Screwdriver operated service valve for hot or cold services. Brass, nickel plated. Part No.Description Unit PriceQty1583215 mm x 1/2" union, straight
Thanks for the info. It's a straight connection, the copper pipe is directly underneath the cistern inlet.
So does one end of that part screw directly onto the cistern, and the other pushes straight onto the copper pipe then? Or are those parts designed for plastic pipe?
Cheers
Reply to Connecting toilet to 15mm copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
