Discuss Connecting 15mm toilet inlet to 15mm isolation valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’m replacing the toilet and it has a 15mm threaded water inlet and I need to connect this to an isolation valve that’s already in place on the copper pipe. Thought it would be easy to find a 15mm to 15mm connecting pipe to screw into both ends but it seems not.
Any suggestions where I can obtain.
Many thanks in advance for your help.
And you're trying to connect to one of these;
Using one of these;
Reply to Connecting 15mm toilet inlet to 15mm isolation valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
