Discuss Condensing oil boiler downsize in the Central Heating Forum area at PlumbersForums.net
Subscribed
It is an ultra low nox burner also
Is it a blue flame? Do you find it noisy?
No it's not a blue flame with the 3rd hear exchanger- it is a Firebird Low Nox with the grey Elco burner.
So today the 1.65gph nozzle finally arrived. Got it installed, set oil pressure and co2. Noted the ppm function of meter is definitely working aok. Starts up in teens then as it runs for a few seconds it drops well into single figures. Just before it reaches thermostat temp it is running 0ppm carbon.
The air had to be turned up quite a bit and its near zero c ambient temp tonight. Got it set steady for 10 mins all good.
Efficiency dropped just a tiny bit with 26kw nozzle but the house is definitely happier with it. Proper heat coming into the rads after only 15 mins of running.
I got a new Bosch Infrared Thermomebter today so in the next few days will balance the downstairs zone then the upstairs zone by proper procedure. (Will be balanced separately as that's how I run it unless someone more experienced advises otherwise?)
Reply to Condensing oil boiler downsize in the Central Heating Forum area at PlumbersForums.net
