Discuss Condense discharge - no easy solution in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Best
Subscribed
This is a common problem where I have to install a condensing boiler and there is nowhere to discharge the condense.
I have an oil boiler to install in a garage and there is only a rainwater gulley close by.
To install a condense trap in the ground is too much work.
I am thinking of using something internal to neutralise the discharge first, before running it to outside.
What would you recommend?
Is there a simple solution?
If pumping to outside then there are lots of choices.
I won’t be pumping it. The garage is above ground level and the rainwater gulley is about 3m away.
Just thought if I can comply with regs to neutralise the condense inside the garage first somehow, then just run to gulley outside
Not a problem best fit a pot in the ground it's a 2 hours job at most fill with limestone chippings up size the condense waste pipe to 32mm and lag up . Or you can get a inline neutraliser again upsize to 32mm after this and connect into the rainwater gully but make sure you have a air break incase of the drainage backs up and lag up . Kop
I'm confused, why do you need to neutralise the condensate before running it to a gulley?
Ok so if the rainwater goes to a soakaway do you have to use the neutraliser? I guess that would be the same if you created your own soakaway?
Yep when you create a condensate specific soakaway you put the lime chippings in there to neutralise, if its going to a general rainwater soakaway you have to do it beforehand.
(still in middle of studdying for my gas safe so might not be 100%)
Just my opinion not to comment on it anymore mate that’s all. You can comment all you want. But I have the GSR badge and it is my A**e on the line when someone doing illegal works points to this website after installing there own boiler with a soakaway. @ShaunCorbs may say it’s fine but still only my opinion.
That`s fine mate, we`ve all got one. However I think it is the forum rather than you as a member who COULD be on the line as you say however unlikely that may be.
Thanks everybody for replies. :)
Yes, the only place I can discharge into is a rainwater gully.
It is an oil boiler job, although I suppose no different than gas.
im guessing separate not combined?
Looks like an inline neutraliser is your best bet then.
Yes, separate according to customer and the house is only 20 year old, so I think he is correct. Just a rain water down pipe goes to it.
Really want to avoid lifting paving slabs and digging outside as too time consuming.
Looks like an inline neutraliser and piping to the gully is your best bet then .
Never fitted one yet, but am thinking that would offer an easy solution.
I have to install some oil boilers in one day if possible and those little parts to the job would take too long.
Its amazing how much time those 'little' extra bits end up taking ***ulatively, its something I often massively underestimated when I started out. Definitely looks like fitting one will be a lot faster than lifting slabs and building a soakaway would be.
I still underestimate the time to do the “little” jobs.
Looking now for lazy ways out where possible :p
Reply to Condense discharge - no easy solution in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
