Discuss Condence termination problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
novicegas
Is it ok to terminate the condence in rain water guttering that terminates in a water drain. Cheers
It's not ideal........ Make sure you fit a tundish as seen many a flooed boiler as when down pipe blocks up it just fills boiler burner till it spews out of fan
No your not supposed to, has to be a waste water drain not rain water. Seen loads done like it though with no issues, apart from what Ermi said.
BG dont bother worryin, if your unlucky the local water company will do you for contamination, but hey more chance of being hit by a fart in a sewage farm.
Surely if its a combined system its ok? Not ideal agreed, but as long as there is an air break with tundish or hopper it would work.
Obviously if its a separate RW/foul then no no.
Im with you there.
∛∜∜∜∝∞∗∖∓∓√∡∢∜∕∝∝∣∣∢∛∛∛℈℁℀ℇℌℋ℄℔ℝℝ℞℗ℭℯ℧Ω℥ℤℬℲℰKℨℵ⅂⅁ⅇⅆℸℶ[emoji671][emoji671]⅞⅘⅝⅋⅜⅊⅛⅕⅛⅔ⅩⅢⅡⅠⅮⅰⅫⅫⅫↂↁↀⅿⅿⅽⅼↄↃ
My thoughts exactly.
Calculated the roughness and is 5
[emoji742][emoji809] for use of obscure emoticons.
A nice idea for terminating condense is..... drill through the nearest outside wall, poke about 2.5" of overflow pipe through, drill a hole in the back of a rainwater hopper, fix downspout to floor level just above pavement, add shoe on the bottom and bobs yer uncle. And yes I know exactly where this is, although not my work !!!!!
Reply to Condence termination problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days it's increased whilst cold...is this a regular problem.
