Discuss Commercial Gas ticket in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, currently domestic natural gas (4 years in) but thinking of commercial gas, is it worth it? .. any advice would be great :)
As your only 4 years I would say no
Do you have any experience in commercial either plumbing or heating ?
I would start out by if you can sub to a few commercial plumbing firms and go from there
Problem is you need the under pinning knowledge else things go down hill fast
There's nothing quick in commercial start with doing a couple of years doing commercial plumbing
Then a couple of years doing commercial heating
Then go for your commercial gas course
If you want to do it enough you will find a way its rewarding working on bigger stuff but not much more salary wise , had over 25years on commercial that was enough for me its hard graft but dont think i would have changed it, now feel like i need to preserve whats left of these old bones so only on a domestic ticket now but good luck to you . cheers kop
Thanks Kop .. thought there'd be a lot more money in it !
If its money your chasing stick to high end domestic stuff which you know about, if not be prepared to work hard and be dedicated it not easy and the commercial accessment is alot harder.kop
Reply to Commercial Gas ticket in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
